02 sensor BS!!!!
Old Aug 1, 2006 | 08:43 AM
miahjera04's Avatar
Default 02 sensor BS!!!!
i have the so very common "check engine light" it constantly stays on, the codes are for the 02's. but i replaced them, and the lights still on still reading 02 codes, any ideas????
Old Aug 1, 2006 | 09:19 AM
soMedic's Avatar
Default Re: 02 sensor BS!!!! (miahjera04)
What are the codes?
I had the problem and it turned out that honda sold me a bad o2 sensor for the front ... also make sure your contacts are clean and wires not fraid bc that will increase resistance and throw codes.... without actual codes.. kindof hard to diagnose.
Old Aug 1, 2006 | 09:22 AM
Inline6 Silvia's Avatar
did you replace them yourself? if so, did you reset the ECU to get rid of the light?
Old Aug 2, 2006 | 02:27 PM
miahjera04's Avatar
Default Re: (SoSoLow)
i went to autozone so they could tell me what codes are being thrown, it was bank 1 02, and also some catylitic BS, i have a high flow cat as well, and i know that contributes to the problem, so i got an upstream sensor, ima bout to put it on, but having the hf cat, is that gonna keep the light on? regardless if the 02 sensors r good, is there anything u can do about that if it does??? like tricks, or secrets?
Old Aug 2, 2006 | 03:45 PM
JSPECSIR's Avatar
Default Re: (miahjera04)
is your car 96 or newer and if so is your high flow a real cat or just a bolt in resonator. if its a 96 up and your cat is just a resonator then its throwing the code cause it sees that theres no cat.
Old Aug 3, 2006 | 01:56 AM
miahjera04's Avatar
Default Re: (JSPECSIR)
i found some of those 02 simulator, and ima put one both my 02's hoping that'll fix my cel's. and hopfully i get to keep the highflow(really a bolt on resonator, cuz u can see right through it) so we'll see.....
Old Aug 3, 2006 | 03:12 AM
JSPECSIR's Avatar
no need to by those, just put a 1 meg ohm resister inline with the 2nd o2 signal wire. should solve the problem and still read mixture off the 1st o2. cost about 10 cents at radio shack.
Old Aug 3, 2006 | 05:14 AM
Heretic:Si's Avatar
just buy some spark plug foulers and put them on the second sensor. you don't use a simulator on the first sensor. there are write ups on this all over the place. just search around
Old Aug 3, 2006 | 06:47 AM
mighty_sol's Avatar
Default Re: (Heretic:Si)
reset PCM, if light lights up check cat for effiency, if not take to dealer to fix lol
Old Aug 3, 2006 | 04:45 PM
miahjera04's Avatar
Default Re: (mighty_sol)
dont got dealer fix money man, lol, so ima stick with the simulator on the bank2 02 sensor, i found one for 15 bux...so i'll b good
shawn5989
Honda Civic (2006 - 2015)
Jul 8, 2008 10:07 PM
preynolds2
Dec 10, 2007 12:30 PM
almostboostedgsr
Mar 1, 2007 06:08 AM
Crossett
Dec 24, 2001 07:08 PM
