ok to fill different oil?
BANNED
ok as some of you know, i had an oil spill problem which the gasket leaked and caused some oil to spill out. i changed the gasket etc and now i noticed that the oil levels reach up to the bottom hole on the dipstick. is that enough oil or am i low?
should i just go buy a bottle of motor oil and pour it in? if so how much should i fill and what brand should i get ;[ what kind etc. i have a d16y8 motor. thanks guys
ps im driving a distance tommorow so i need to know asap
BANNED
Re: (axtran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axtran »</TD></TR><TR><TD CLASS="quote">err gauge oil between the two holes on the dipstick. use the same oil that you have in the car, should be 5w-30.</TD></TR></TABLE>
the car was running on the oil the honda dealerships gave. is it ok just to go to autozone and pick up another brand like mobil?
also what do you mean guage between the two holes. hmm the reaches up to the first hole
BANNED
Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">You don't have to buy Honda oil. Just go to Autozone, Kragen, etc.
Normal operating oil level will be between the two dots. The second (highest) dot is the limit. Anything below the first dot, add oil until you reach the top dot.</TD></TR></TABLE>
ok thanks,
lets say its at the first dot maybe like a cm below. is it safe to drive 40-50 miles?
ok thanks,
Re: ok to fill different oil? (VALENTINE)
The first dot and the second dot is about 1 qart difference. So if the oil is on the bottom hole then it will take about 1 quart to reach the top hole.
BANNED
Re: ok to fill different oil? (byronl)
hey guys, today i bought 5W-20 oil from honda. i only have about 30-40 thousand miiles on the car so its 5W-20 OK to use?
Ek Forever y0!
Re: (Mistermark)
Wanna swap post numbers? Dude, where do you post?
Yes, you could really buy 12 different kinds of non-synthetic 5w-30w, mix it all together, and use 4 qts in your engine, and have the same effect as using 'honda' oil.
Wish2345
26
03-23-2010 01:47 AM
