cel 43
cel 43
ive just rebuilt my b16 a2 new bearings,rings and head set but my cel keeps coming on and is showing 43 which i beleive is fuel supply system i have changed my fuel filter put injector cleaner in it and replaced the 02 sensor as well with the one i had in the garage in my standard downpipe i then reset my ecu but the light still comes on after driving or letting it idle for about 20 mins is there anything else that could be causing this any help would be appreciated thanks in advance
Re: cel 43 (wullie_vtech)
43 is not a valid code in the Honda service manual for 96-00, it is not listed, are you sure it is 43? you know how the codes work right? long light is 10, and short one is 1. I'd recheck.
Re: cel 43 (slowcivic2k)
i have its b16 a2 vti with p30 ecu i already called honda and they said it was the fuel supply system and they said it could be the pump pressure is there anything else it could be
Hrm, I have a 92-95 honda and it's throwing the same code...BUT ONLY SOMETIMES
and I can't get rid of it
fuel filter was chnaged...fuel pump works fine...no cut outs, no nothing...ran fuel injector clearner through there...
Just like, maybe once a month it'll come on
Until it starts affecting something I'ma ignore it....but u can't do that if u need it inspected b/c it's ODB II can you?
Blah
It's annoying ;( Mine's completely spontanious, could turn on 3 minutes from my h ouse, could drive it 5 hours and not come on at all...
Weird ****, wish I could fix it ;(
Blah
Re: (cockerkid008)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cockerkid008 »</TD></TR><TR><TD CLASS="quote">i have the same exact code but it runs perfect nothing wrong, ive changed the filter also</TD></TR></TABLE>
Word, same here, some fucked up ****
Re: (Syndacate)
i know it seems fine but i dont really know if its ok as im running it in and cant go over 2000 revsfor a thousand miles so i thats why id like to get it out thats why i asked on here as honda cant tell me anything i dont know and they tried to tell me that theyre the only ones that can reset the ecu
Re: (wullie_vtech)
its prolly fuel tank pressure sensor. i had that problem happen to my friends 93 civic dx, he didnt think a gas cap could set off a check engine light, guess it can XD.
E-brake or Handbrake
18
11-05-2004 08:11 PM
