overheating..... need help
Car is overheating when idel......just changed thermostat, refilled coolant, and it was fine for 2 days.... then overheat again when stop.....temp drop back down to normal when moving, then overheat when stop.....no white smoke coming out, any idea? Help please...... Also how do you know if you have a blown gasket?? Thanks in advance guys!!
Re: overheating..... need help (EK VTi)
if you had a blown gasket, the performance of the car would be really bad, not to mention you will see white smoke.
burb the system. the one thing people either forget or overlook.
let the car cool, open the radiator cap, start the car, pour more fluid into the radiator until you can't no more and then close the cap back up. and then you'll be all done, you shouldn't have a problem then!
Re: (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">So it's only overheating when at a stop? I would check to make sure your cooling fan is engaging. I have a feeling it is not.
Cheers.</TD></TR></TABLE>
x2
x2
Depressionused
05-16-2007 12:49 PM
civais
04-11-2005 02:47 PM
