window stuck on 99 si...need help asap!
my window on my driver side will only roll up about 6 inches and then it gets stuck and wont move at all. the higher it goes up the farther it gets off track. its really rainy here and i dont want to have my window open for theives to go stealin my **** so any help on fixin my problem is appreciated!
remove the door panel
behind where ur speaker goes u can see the bottom of the track
remove the bolt holding it then push it forward & put it back onto the window
after that lube it up...
so it wont happen again
Modified by tha_badguy at 4:49 PM 8/2/2006
Re: (tha_badguy)
^^^^...there should be two 10mm bolts holding the tracks in place. Take the bolts out and slide the windows back in track...
Modified by sohc_coupe24 at 8:22 AM 8/2/2006
Re: (tha_badguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy »</TD></TR><TR><TD CLASS="quote">remove the door panel
so i wont happen again</TD></TR></TABLE>
x99999999999999999999999999999999999999
Re: (sicksiguy)
i only know this because its only happened to me like
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harryflores »</TD></TR><TR><TD CLASS="quote">
99999999999999999999999999999999999999x's</TD></TR></TABLE>
TwoKSiR
11-04-2007 02:33 PM
00ekcoupe
13
08-27-2005 10:52 AM
RedDC5
02-20-2005 11:00 PM
JDM-FREAK
12
05-17-2003 12:31 PM
