itr cams into a b16
itr cams into a b16
hey guys, i've tried searching but couldnt find anything so i thought i'd ask, if i was to put itr cams in my b16, is there any valve adjustments needed, and would there be any valvtrain problems in the long run if i dont up grade to itr valvtrain....
Re: itr cams into a b16 (Slow_import)
not really, since it is an upgrade, it is not a drastic of an upgrade. IMO, if your planning on putting them in you might as well do a valve adjustment. kill 2 bird with 1 stone.
Re: itr cams into a b16 (SkoundrelUSA)
well the thing is i heard that if i dont do the valve adjustments at certain rpms you hear a slight knock....but i dont know if its true, and i just wanted to know if the valve adjustment is very neccessary if i plan on reving to 8 grand only....
regardless if you have the cams or not, when a adjustment is needed they will tap. that's how all hondas are and should be part of your routine maintence. but you can stll take it to 8000.
Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic »</TD></TR><TR><TD CLASS="quote">any time you install cams you want adjust valve lash </TD></TR></TABLE>
exactly.
exactly.
Re: (Slow_import)
my god, your acting as if valve adjusting is a hard and grossly long process, its pretty easy to do, theres even a few write ups on it.
i know tha IT-R's titanium springs & retainers are recommended, but are they absolutely required? will i be able to run tha IT-R cams safely w/o them?
_taF
_taF
