wire harness
wire harness
i have a 92 cx with a 01 gsr motor. i'm in need of a new wire harness becuase the one that was in the car the ecu plugs were cut. can i just buy a obd2 harness and connect it right up? is it 2 peice like just teh ecu side or would it be one whole harness that goes to the cluster as well?
Re: wire harness (dthug)
can i just use the passenger side wire harness from a obd2 gsr so i wont have to wire up vtec and all that but use my stock civic harness on the drivers side?
replacing the harness is a pain, and I wont do it again, its better to run wires yourself, because you know that harness works, plus the added wires for vtec and all. http://www.spoonhonda.com wil get you a manual for your car, check it out.
kodamoose420
11-13-2013 03:10 AM
