Fuel Pump????????
Fuel Pump????????
Whats up,
OK, I think my fuel pump **** the bed. I try to start the engine and I don't hear the buzz in the back.
Simple replace, or is it something else?
Thax people
Thax people
Re: Fuel Pump???????? (BlueIntegraBoy)
check the thermostat ground as well, that will prevent it from turning over, since it ground the main relay, it being loose or disconnected will not allow the fuel pump to work.
Re: Fuel Pump???????? (Stubs)
Put a circuit tester in both plugs to the wiring running from the front for the pump, and no light.
So..... Its something els.
Wich fuse, or relay????
Thanx guys, again!!!!!!!!!
cute little bastard
Theres a main relay near the cabin fuse box. Its a little more to the left and its bolted in with a 10mm. Looks like a grey box. (10mm was removed in the pic)
Try switching with someone first before you buy to see if it actually is bad or not.
if it is the fuel pump it is easy to swap out.
Take out your rear seat bottom.
Take off the little metal cover. (4 philip screws)
Remove the 4-5 10mm bolts holding the fuel pump in.
cute little bastard
Re: Fuel Pump???????? (delslowly93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslowly93 »</TD></TR><TR><TD CLASS="quote">check the fuses under the dash, its got to be one of them </TD></TR></TABLE>
ok, which one?
ok, which one?
Thax for the help poeple.
The strangest thing happend just now. Went to work on the car, and i noticed that i left the power on, and i thought O-****, my bat. dead.
turned the motor over,.........and it started right up. ****** AWSOME!!!!!!
94delsol6428
12-27-2006 07:06 PM
iHave2Cams
05-05-2003 04:29 AM
