EG hatch with h22 help!!!!!!!!!!!!!
hey i have a 92 civic with a h22 and it is not starting. it will crank over i also dont hear the fuel pump turn on. i just got a new fuel pump and it didnt work... and i also got a new main relay and still nothing. please someone help me out!!!!
Re: EG hatch with h22 help!!!!!!!!!!!!! (EGG_y0)
Does your check engine light come on when you turn the ignition on for about 3 seconda then turn off? if so, the ECU is good and the may have a wiring problem. If not check, the ground on the thermostat housing, it's the most common problem. If it does, do you have a spare odb1 ecu (can be from any honda) you can plug in and turn on the ignition to listen for the fuel pump to turn on. If it does turn on with another and not the H22 ecu. the H22 ecu has a problem.
Re: EG hatch with h22 help!!!!!!!!!!!!! (Cvic90)
ill go and check that ground and no i dont have a obd1 ecu but how could it be that when it was just working a few days ago?
Re: EG hatch with h22 help!!!!!!!!!!!!! (lucky4586)
well i got the fuel pump to turn on now but its still not starting and now the check engine light comes off then turns off
y0whuddupb
31
08-09-2006 01:16 PM
