02 sensor problems
02 sensor problems
I have a 98 honda civic with a drag 3 kit. I also switched it from a obd 2 to an obd1. My problem is that i am getting a weak signal from my o2 sensor which i causing the car to run rich. I bought a new o2 sensor and still have the same problem. I also had to extend the factory harness to the sensor due to the location on the downpipe. Can anyone help me find a solution?
Also todayi tried to rewire it to make sure it was not that and hooked up the white and green wire backwards. Now getting a check engine light on all the time. Could i have fucked up the ecu????
Re: 02 sensor problems (SomeFool)
It is an OEM replacement made by a company called Standard......not a Honda Factory Part BUT I have a used O2 sensor made by Honda that I purchased on Ebay and get the same results as the new one I just bought!?!?
