B18c1 engine swap problem
my buddy just swapped a b18c1 into his ek hatch, and everything is ready to roll. it drives fine when going straight, but when he turns they CV's click. but they have changed them back and forth and always the same problem. any ideas what else it could be. is it possible its not the cv's or there the wrong size?
any help is good help at this point.
thx.
thx.
Former Moderator
Re: B18c1 engine swap problem (_silverTEG)
What type of CV joints are you guys using?
You should be using any 94-01 Integra, 94-97 Del Sol VTEC, or 99-00 Civic Si axles. ABS or not, it should not matter as you don't have ABS and the ABS axles only difference is the ABS rings on them.
I'd say you got some **** axles.
If he has LSD and it's clicking, then he's got more than just axle problems...
Re: B18c1 engine swap problem (B18C5-EH2)
either you need to replace the driver and passanger outer axels or you have lsd problems of some sort..i dont know much about lsd..but axels are about 60 bucks a piece from napa for a 94 del sol dohc vtec 1.6
moonmotorsports
11-12-2011 02:52 PM
