question on msd stuff
ok i bought a msd cap and blaster 2 coil. i installed it and hooked up everything like msd said. when i would drive i noticed a loss in power mostly in mid and low range rpms (runnin lean). so i uninstalled and put stock cap and coil on. now i have a b&m fpr at 40 psi. and i am curious to know if installing the msd stuff will help with power now? by the way the engine is a jdm d15 vtec, with ngk irdiums, i/h/e, and A Peice of Crap wires. thanks for help
Re: question on msd stuff (Louie_EM1)
maybe he was spark knocking (whicj he could hear) or maybe he has a wide band.
jagolas you need to throw some more details out here.
Re: question on msd stuff (SprayinCX)
ok no i don't know for sure that i was runnin lean before or after the msd. but i know i lost power in mid and low range. and i did tell a differnce after i took the msd off. i know i was runnin lean while the msd was on bc of the plugs. it's easy to tell anything by those. i wasn't spark knocking and i know for sure that my timing is perfect. and i changed them twice in a month to make sure what was goin on.
