doing auto to manual swap tomorrow anything else i need to know
i have a 96 hatch auto
97 ls 5speed donor car
im doing my swap tomorrow
anything i should need to know before i start
doing rear disc brake conversion tomorrow too. me and one of my friends are doing it hopefully get everything done in one long day
one question i jsut want to make sure on
to bypass the box so i can start my car and take the key out
connect the two fat wires i think they are black and black with a red stripe
and the the small black wire to the green wire with a black stripe?
nething else
i have all the mounts del sol ac bracket hopefully everthing i need try to take pictures if i remember
nething else
Re: doing auto to manual swap tomorrow anything else i need to know (ICEDOWT)
I'd like you to keep me informed on your progress and headaches, have 91 with automatic that I want to swap to 5-speed, would like to know what I am up against.
Email Me Direct, uhurlis@yahoo.com, if you have the time.
Good Luck!
The CoolMule
Good Luck!
The CoolMule
finished everything in one long day ls swap converting car from auto to manual
rear disc brake conversion and integra front brakes too tokico shocks ground controls dc header act clutch all kinda **** the hardest part was figuring out which wires to tap to let you take the key out
and they are the two BIG wires black/white stripe and black/red stripe
and then green with a white stripe and green with a black stripe. also make sure all you other plugs are undone connecting to the shifter assembly or it still wont let you take keys out
Modified by ICEDOWT at 6:14 AM 7/12/2004
joshb_
20
03-15-2007 05:41 AM
SlamminS85
08-15-2005 01:53 PM
