help with cable to hydro swap
i have a 97 integra ls motor that was runing a cable tranny but know i want to run a hydro tranny what parts do i need to change
Re: help with cable to hydro swap (94_civicEx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_civicEx »</TD></TR><TR><TD CLASS="quote">i have a 97 integra ls motor that was runing a cable tranny but know i want to run a hydro tranny what parts do i need to change
depends on what tranny you have:
if you have 90-91 tranny then you'll have to change out your clutch disk
if you have 92-93 tranyy then you'll be fine
next depending on your chassis:
Tranny mounts
you'll need to get the front torsion mount for the front of the hydro tranny. If you old engine had the top mount for the tranny you'll be fine and use that one.
Rear Tranny Mount
if your car is a 92-95civic/93-97 del slow/94+ teg:
use a 94+ teg 5 speed rear mount
if your car is a 96+ civic:
then use 99+ SI rear mount
based on your questions leaves the door wide open to more comments.
need to know your chassis? was this swap in a different car and now being swapped into a new car? please post more info
Tranny mounts
Rear Tranny Mount
it is going into my 96 civic hatch and i have all the mounts already needs to know if i can use a cable tranny culuth on the hydro
vtec25
17
10-03-2006 06:57 PM
bossman032
12-10-2004 09:53 AM
