98 civic head gasket is bad
Old 07-01-2004, 02:34 PM
jman30513's Avatar
Default 98 civic head gasket is bad
any links out there for changing out a 98 civic ex sohc vtec head gasket?
very small leak in mine causing temp to flucuate
gonna do this myself with all of yalls help!
and yes i did say "yall"!
ty, jman
also, im running a greddy kit on my 1.6
Old 07-01-2004, 02:36 PM
EL Vap133's Avatar
Default Re: 98 civic head gasket is bad (jman30513)
I would suggest you have someone else do it.
Old 07-01-2004, 02:44 PM
98CivicEXT's Avatar
Default Re: 98 civic head gasket is bad (EL Vap133)
Pick you up some ARP headstuds for a D16Y8 and a new OEM gasket or Cometic HP one. Get a helms manual and have at it. It's really not that hard. Remove timing belt, downpipe and move turbo out of the way (mine I just dropped down a bit), remove the intake, then take the head off by loosing the bolts in sequence specified in the manual. Get the head resurfaced and checked over just to be safe. Next put the new ARP studs in, put the new hg on and put everything else back in sequence. Done.
redright9
01-14-2011 05:01 PM
boost junky 71
05-26-2004 10:07 AM
TurBoXBirD16
04-15-2003 09:30 PM
Albino Dragon
01-24-2002 12:26 PM
Quick Reply: 98 civic head gasket is bad
