Power Steering Question (High Pressure Hose)
Ive got a 96 civic ex coupe which used to have the 1.6 sohc vtec motor in it...Well I just recently did the b18c1 gsr swap in it...well the high pressure power steering hose on my car does not fit the new gsr power steering pump. Any idea's on what hose i should replace it with...I need one side to fit my 96 civic and the other side to fit the gsr pump...any suggestions!!!
Re: (SC-MK1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SC-MK1 »</TD></TR><TR><TD CLASS="quote">A power steering line from a GSR will work.</TD></TR></TABLE>
I disagree because I believe the GSR line will not fit the civic rack.
I'm guessing the "nipple" from the civic's line is smaller than the hole that accepts it in the GSR PS pump, right? You'll need to get a 93 or older B-series PS pump from the junk yard. It has a smaller hole to accept the civic's line.
Re: (jbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbs »</TD></TR><TR><TD CLASS="quote">
I'm guessing the "nipple" from the civic's line is smaller than the hole that accepts it in the GSR PS pump, right? You'll need to get a 93 or older B-series PS pump from the junk yard. It has a smaller hole to accept the civic's line.</TD></TR></TABLE>
I got a power steering line from a JDM DC teg when my line broke, and it fit the pump on my B16, and the rack in my hatch with no mods.
Re: (jbs)
Well the power steering hose on the car now the end that bolts to the pump is too big to fit into the hole on the top of the jdm b18c1 pump...so i really needs to be smaller..
Re: Power Steering Question (hondacivic2nv)
Back from the way dead.
Doing an obd1 jdm b18c gsr swap into a 99 civic dx. What ps pump hose do we need to make this work? The hose that came with the swap is cut and the fitting on the stock dx hose to the pump is too large to fit into the gsr pump.
Thanks
Thanks
Re: Power Steering Question (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman »</TD></TR><TR><TD CLASS="quote">Back from the way dead.
Thanks</TD></TR></TABLE>
Never-mind...we just looped the rack.
dont do that , youl ruin your rack. either mount the D pump in the B brackets , if that wont fit since ive never tried that one personally. or , cut your original power steering line on a straight part of the line , and on the steel line , do the same with a B series PS line , cutting it in the same spot , and also on a straight piece. join the 2 together with a compression fitting , and pow there ya go. power steering line. compression fitting wont leak. just dont hurt it when tightening them up. if you opt to try and get a D series pump to mount in the brackets , the pullys might not line up correctly , if this is the case , use washers to line the pullys up so you wont wear through belts. besides where the lines going into the pumps being different , the way the pump mounts in the car is near the same in civics and tegs.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Gabe....If you really want ps back......use an em1 pump and stock ek lines (this is a hot topic lately, and no one is researching)</TD></TR></TABLE>
I searched the crap out of this topic...and nowhere did I find that I could use an EM1 pump. I figured the d-series pump was different from all b-series pumps, (the high pressure hose fitting on the end that connects to the pump).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cranny »</TD></TR><TR><TD CLASS="quote">Either mount the D pump in the B brackets , if that wont fit since ive never tried that one personally. or , cut your original power steering line on a straight part of the line , and on the steel line , do the same with a B series PS line , cutting it in the same spot , and also on a straight piece. join the 2 together with a compression fitting , and pow there ya go. power steering line. compression fitting wont leak. just dont hurt it when tightening them up. .</TD></TR></TABLE>
We looked at that option...but the d-series pump would not mount correctly with the b-series motor. Have you ever tried the high compression fitting/splicing the two lines? That sounds like an easy/cheaper fix.
https://honda-tech.com/zerothread?id=1822403
https://honda-tech.com/zerothread?id=1822092
https://honda-tech.com/zerothread?id=1808242
https://honda-tech.com/zerothread?id=1809078
These are just recent too.
Try searching "in thread bodies" not just titles
I need to make a thread about this for the FAQ...
Re: (pdiggitydogg)
Thanks. I'll keep that in mind when I do my swap. Now I know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">I need to make a thread about this for the FAQ...</TD></TR></TABLE>
That would be great.
HRD PKR
Re: (gabebauman)
i have a type r in my 96 coupe i just used the stock d series line.. nothing messed up at all. used a type r power steering pump to.. which is close to the same as the si.. so u can use the d series line on a si pump
94_gsr_civic
01-06-2014 05:43 AM
