White reverse lights are flickering
When I put my car into reverse the lights flicker on and off. I found a wire that connects to the tranny is just above the tranny that needs to be replaced. When I move it around my reverse lights stll flicker but stay lit more constant. I'm sure now it's just a faulty wire. I checked the local autostore for the name of the wire but they didnt' know what I was talking about. I looked for a Helms and Haynes manual but the store only carried Accords.
FIY I replaced the bulbs already and checked the wire connections for the rear lights. There is a picture below of the wire I am talking about. Any help is appreciated. If it matters at all its a d16z6 motor. (In desperate need of Simple Green cleaner )
Re: White reverse lights are flickering (Efil4zaggiN)
That's the wiring to the reverse sensor in your transmission. You could always try following the wires down, removing the reverse sensor and then reinstalling it to see if that helps.
1 Post
Re: White reverse lights are flickering (xerox445)
I had the same thing happen to mine and eventually the reverese sensor died.
I had to replace the switch...
#6 on this page from Honda automotive parts... 24 bucks...
http://www.hondaautomotivepart...USING
mitchh29
31
03-30-2013 12:13 PM
jbpnoman
35
08-18-2012 02:16 PM
jdmej814
Lighting
01-30-2008 02:07 PM
