car is running sluggish at low RPM
I got 00 civic EX with 40k miles. On higher RPm car runs good and I get really good gas mileage. But it is running sluggish at low RPM. No matter how much gas I give it won't run faster and it feels like there is no torque.
So far I have done these things
1. changed spark plugs and wires
2. changed air filter
3. Swap ECU from my other 4dr civic
4. Checked timing ( thanks all H-T guys who helped me out checking timing)
Now can someone tell me what is wrong with my car?
thanks guys
EDIT: I have notise one thing. When engine is cold my timing belt is loose. But after driving car when I check timing belt it is tight (when engine is hot). Is it normal?
Modified by Jaydeep at 5:03 PM 11/2/2004
thanks guys
Re: car is running sluggish at low RPM (_Project EJOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Project EJOne »</TD></TR><TR><TD CLASS="quote">It's a 1.6, how much torque do you want?</TD></TR></TABLE>
Well I got 4dr civic EX and that car runs good even at low RPM. So there is some thing wrong with my 2dr one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Project EJOne »</TD></TR><TR><TD CLASS="quote">How does it run sluggish? Does it seem to lag or stall a lil, or what? Have you done a compression check?</TD></TR></TABLE>
Car is stalling a lil.
What is compression check? Can i do it by my self?
Re: (jay-spec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay-spec »</TD></TR><TR><TD CLASS="quote">How is the battery grounding terminal and voltage? Last time you replaced the cap, rotor?</TD></TR></TABLE>
I checked cap and rotor. They are good.
Re: (DemostheneZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DemostheneZ »</TD></TR><TR><TD CLASS="quote">it's a civic, what do you expect</TD></TR></TABLE>
[QUOTE=Well I got 4dr civic EX and that car runs good even at low RPM. So there is some thing wrong with my 2dr one.[/QUOTE]
Re: (Jaydeep)
Yes, you can do a compression check yourself. All you need is a compression gauge, which can be purchased at Sears or something. Do a search on compression check.
Re: (_Project EJOne)
Re: car is running sluggish at low RPM (benitom)
Check the ignition timing with a timing gun. If you can't set the timing to spec, check whether the timing belt skipped a tooth.
Re: car is running sluggish at low RPM (Jaydeep)
I know you said you checked your timing, but your problem sounds just like the problem I was having. My problem was that when my timing belt was changed (prior to me owning the car!), the mongoloid let the intake cam advance a tooth. From 500-3000 RPM's, the car drove like crap, but from 3500 - 6000, it was it's normal fun & peppy self. Simply removing the belt, putting BOTH cams @ TDC, then redoing the timing fixed the problem. Just something very simple to check.
Edit: OP: How the hell do you have a 2000 EX with only 40k miles on it? I worked from home for a year and a half and put more than 5000 miles / year on my car...
integra3586
10-15-2005 01:56 AM
Jaydeep
19
10-21-2004 07:10 AM
Jaydeep
09-02-2004 01:39 PM
