EXHAUST VALVE? WTF
EXHAUST VALVE? WTF
ok, heres the deal. b16a2'd ex
all the bolt ons, exhaust... straight thru, no cat, dc 4-1 headers, thats all that matters i think, anyway.
could i have a bad exhaust valve or somthing that isnt sealing when my car is idle, or off, im losing alot of oil, more than should be lost, when i start my car, my exhaust shoots out some sutty terdish stuff that is all black and wet, kinda powdery too. bad valve spring?
help me out.
help me out.
Re: EXHAUST VALVE? WTF (joedubovik)
well if there is none under it you got to be burning it so it could be a valve, valve spring, or piston ring good luck
What kind of oil are you running? If it's Mobil 1, I've heard from many people that both B and D series engines like to drink Mobil 1. Why? I have no clue.
Re: EXHAUST VALVE? WTF (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life »</TD></TR><TR><TD CLASS="quote">What kind of oil are you running? If it's Mobil 1, I've heard from many people that both B and D series engines like to drink Mobil 1. Why? I have no clue. </TD></TR></TABLE>
My K doesn't, but my D15, D16, and H22 do.
Re: EXHAUST VALVE? WTF (Jim Truett)
full synthetic castrol 5w-30
theres no way engines can eat up as much oil as im losing.
thanks guys, keep the ides/ suggestions comin.
Re: (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">does your air filter/tubing have oil in it??</TD></TR></TABLE>
dont see why it would...its not turbo'd
Re: (2thousandcivic)
hmmm, welll ill check my filter tubing tom. im pretty sure its dry, as for dipstick popping out, no, valve tapping, no ( i dont think) would it be reall noticable, my car is so fruggin loud i cant even hear my engine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2thousandcivic »</TD></TR><TR><TD CLASS="quote">
dont see why it would...its not turbo'd</TD></TR></TABLE>
doesn't have to be turbo to have oil in you intake tube but There's the air release valve that run from your cover to your intake. most turbo cars have a catch can between there and the intake but since this is not. you still can build up pressure a well you got a nice mess. you can always check it and rule it out.
Re: (92 CIVIC HATCH VX)
ill check it out guys, hmm, im gonna do a compression test tom. too to rule out pistons, or diagnose my disease.
If ur car smokes when u start it up but quits, that usually indicates valve guide seals- engine turns off, oil is collected in cylinder head, sits, seaps down through worn valve guides or valve guide seals and is let into the combustion chamber during starts up, producing the smoke.
Re: EXHAUST VALVE? WTF (4thgen92accord)
yeah, mah pops said valve seals, how do i test for it?
leak down? i dont understand what a leakdown tests, besides leaking down of somthing.
Re: EXHAUST VALVE? WTF (GaiSensai`)
yay, havnt tested yet, oooo
when doing a compression test, does it matter what my oil level is?
n00b question prob. oh well. help me out brothas.(and sistas)
wrd. to the top
wrd. to the top
What does the oil in the intake tube signify again? Because i know when i went to put a CAI on my civic there was a red looking oil substances in the stock tube. thanks for any help and sorry if i am stealing this thread
THIS JUST IN. i just checked my oil, and after adding two quarts like 3 days ago, my oil is already nasty brown/ black, iknow oil goes dark but this fast?
Mr. Badwrench
Re: EXHAUST VALVE? WTF (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">well if there is none under it you got to be burning it so it could be a valve, valve spring, or piston ring good luck</TD></TR></TABLE>
it would be more along the lines of rings or valve seals. a burned exh valve really wont cause it to use oil. although stranger things have happened. go get some top engine cleaner from gm and do what the instructions say. if the rings are stuck it will free them. i have heard all good about seafoam on here but havent tried it myself yet. i have always used GM Top Engine Cleaner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joedubovik »</TD></TR><TR><TD CLASS="quote">THIS JUST IN. i just checked my oil, and after adding two quarts like 3 days ago, my oil is already nasty brown/ black, iknow oil goes dark but this fast?
sounds like you have water in your oil....how much coolant do you have?? are you eating that too?
edit: just reread that....nevermind.
