Just finished swap (3rd swap) Now drivers side headlights, tailights and signal malfunctioning.
Ok so Ive just done my 3rd swap in my car. The drivers side lights seem to not be working right when I switch the headlights on. The driver side headlight is dimmer then the passenger side. The signal light on my cluster stays dimmly lit up, and hyper blinks as if I have a burnt out bulb. Allready switched bulbs, they all work. What could be causing this?
1 bad grounds in the system?
2 I did remove the canadian day time running light module off of the car. Could this affect it.
Pictured here drivers side shock tower-
But this did not affect the passenger side lighting at all. I need to figure this out before I install my hids. Thanks guys..
Re: Just finished swap (3rd swap) Now drivers side headlights, tailights and signal malfunctioning.
Had the same problem, found out my ground box wasnt mounted right and wasnt grounded at all. Try that.
Cool...where is the ground box? Ive never heard of this.
marks97el
02-03-2012 02:32 PM
hammerdgolfer
06-11-2007 05:11 PM
