Fuel filter and transmission
guys, i tried to change the transmission fluid for the first time and couldnt even open up the filler plug. thank god that ididnt drain the fluid so i m good for now. Any advise on this. Its seriously tight. Also its 2003 ex civic, i couldnt find the fuel filter. is there any place to look for. The milage i have are 30k. any advise would be really helpful. Thanks
Re: Fuel filter and transmission (return_2020)
I'm not sure but my parents 99 accord got a fuel filter in the gas tank. Could be the same thing with yours. So it doesn't need to be changed unless your fuel pump goes out. check some parts diagrams on hondaautomotiveparts.com
The fill plug get a nice 6 point on it (not some weak piece of ****), and tag on it until it breaks loose.
if its a return less fuel system i has a fuel filter in the pump and dosent need to be changed unless the pump goes out and i have allways used honda mtf unless it had lsd then i used synchomesh im not positive check some diagrams for the fuel filter
pjr710
04-03-2010 05:59 PM
