Shocks issues?....
NASIOC.com
Shocks issues?....
Every time i hit a speed bump my shocks make this distince sound like they are rubbing on something... I dont know if the shocks are done for or there is something that i did to them... BUT, I have checked them out and they look fine... Did my maxspeed coil overs break my shocks?
Re: Shocks issues?....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy92 »</TD></TR><TR><TD CLASS="quote">its was like a 2in drop on stock shocks... Did i blow them out?</TD></TR></TABLE>
I would put money on it. Your OEM shocks are probably not anywhere near capable of keeping up with the much stiffer spring rates, and I'd bet they're toast. The noise you're hearing is probably the shocks against the bump stops.
Re: Shocks issues?.... (Otherguy92)
look for oil around the shocks i bet they done my friend lower his car on s.tech tein springs the stock shocks blew out very fast. 2months.
Without really knowing what your spring rates are, I imagine you'd probably be fine with a set of adjustable Koni yellows. Most people run them with the 350-400 lb Eibach/Ground Control coilovers with good results. Most street springs are in that neighborhood (or less), and the Koni's valving will handle it well.
aleks77
08-13-2005 02:38 PM
