B16A VS B16 SIR2
B16A VS B16 SIR2
I've been researching swap options. the sir2 is $600 more. Is the sir2 worth the extra cash for the 10hp and 5lb ft tq. I would most likely be boosting it with either a jackson racing sc or a low boost turbo kit. Looking to keep the internals stock. If I go with a SC. what about the jackson racing race header? I searched and found no info on the header as far as how it performs. found info. about the kamikaze and dc both on a gsr.
Location: With my POS D15B2, Whereever whenever, United States
Re: B16A VS B16 SIR2 (Spins)
b16a sir2 is for obd1 and 96-00 is for obd2 cars
your b16a is obd0 so if your car is 92-00 get a b16a sir2
Re: B16A VS B16 SIR2 (MugenHonda)
I have a 95 hatch. I've been going back an forth about what swap to do. trying to research and not ask some of the more common questions.
is 2400 a good price for a Sir2 with tranny,linkage, ecu, axles. with lsd 2900.
ok the big dif. on these engine is b16a1 is a cable tranny set up and the b16a2 is a hydrolic tranny. your tranny mounts are already made for hydrolic tranny. you would have to also buy a custom cable tranny mounting kit if you choose the b16a1.
and b16a2 i can do 2600 for the swap with lsd shipped to a resudential or business ,address that can unload the engine. engine, ecu. harness, tranny, shiftlinkage, Axles<used add $50 for new axles> and lsd.
Re: (jerbear!)
I'm just trying to research. I like the idea of a b18. Dont know if it's worth the extra cost. I was also toying with the idea of a sohc vtec with a greedy turbo. These engines seem to be fairly cheap and with a turbo can beat upon na b16's an b18's with bolt ons for less cash.
Re: (jerbear!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! »</TD></TR><TR><TD CLASS="quote">are B16's your only choice? Remember theres no replacement for displacement (hint hint b18b good for turbo too!).. </TD></TR></TABLE>
You're saying more displacement is better but you only went up 0.2liters? H22's and k24's have much more displacement.
Re: (eL)
i got the b16a2 and swapped it for the jdm b16a sir2 with lsd and now i regret it... if i had to do it again i would go b18b and turbo it for the cost of the b16a sir2 and i would have more torque and hp...
Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL »</TD></TR><TR><TD CLASS="quote">
You're saying more displacement is better but you only went up 0.2liters? H22's and k24's have much more displacement.</TD></TR></TABLE>
i was merely trying to stay within his price range. he was looking at b16s and an LS is comparable to both, even cheaper.
for headers....get a set of 98+ ITR headers. they make more power than the dc's and others. i forget where i saw it, but it was significant enough to pay a little extra for the true jdm headers.
sweetbai00000
03-27-2007 09:23 PM
CivicTypeR
07-14-2001 02:45 PM
