brake pedal goes to floor
im not leaking fluid!!!!!!!!!!!!!
ever since I took off the axle nut its been doing this. Why would it do this!!!!
94 cx hatch
im getting new brakes tuesday (pads)
i cant understand why the pedal would go to the floor. is one of my lines ballooning?
if I pump the pedal it stiffens up
94 cx hatch
Vice President/CEO
Re: (lax1185)
try bleeding them... if that does not fix it then you've possibly got a busted up *** Brake Master Cylinder.
My del sol did the same thing... switched out the master cylinder and the problem went away'
Re: (kKdARIAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kKdARIAN »</TD></TR><TR><TD CLASS="quote">try bleeding them... if that does not fix it then you've possibly got a busted up *** Brake Master Cylinder.
My del sol did the same thing... switched out the master cylinder and the problem went away'</TD></TR></TABLE>
correct.
correct.
Re: (mebri)
Yeah, bleed them. Pump tha shiet ouf of it to get ALL the air out. If that doesn't do it, then, yeah... your MC should be replaced had that same problem with my first Si.
Risky Business
Re: (mr. teal Type R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. teal Type R »</TD></TR><TR><TD CLASS="quote">how much are MCs</TD></TR></TABLE>
Did you bleed the brakes like everyone told you first?
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
Did you bleed the brakes like everyone told you first?</TD></TR></TABLE>
no i havnt....but I still have a right to know how much MCs are
Re: (jaedaSC)
if you don't wanna spend a grip of cash on a new MC you could just go to honda and get a new seal for the back of the MC and your prob will be fixed for like 10.00 plus some silicone grease. This is the route I chose and my sinking pedal problem was fixed. Of course after you take off the MC you'll have to
.......................Bleed the brakes.............. jk
hope this helps
ps look under your mc and see if any fluid is coming out or if it looks like it's leaking.
hope this helps
Re: (hellshock2182)
u got an eg? i got a my old brake booster laying around i upgraded to a gsr one
edit nm u got a eg lol but yea i got the brake booster off my cx
Re: brake pedal goes to floor (mr. teal Type R)
if you are getting a pedal when you pump it up, then it is most likely your master cylinder. your primary seals are gone and then only seal when you pump them up. i would change the master. does the "brake" indicator in the cluster stay lit?
if you had air in the system, then it would be a spongy/springy pedal. bleed as much as you want and the pedal will still go to the floor.
i would suggest getting the correct MC for your car. different MCs from different hondas have their brake lines coming out of different locations and it would be a bigger mess to bend lines to make things work. just get the right MC and forget about it.
Re: brake pedal goes to floor (ten_30)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ten_30 »</TD></TR><TR><TD CLASS="quote">
i would suggest getting the correct MC for your car. different MCs from different hondas have their brake lines coming out of different locations and it would be a bigger mess to bend lines to make things work. just get the right MC and forget about it.</TD></TR></TABLE>
good point
good point
Re: (blaster834)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaster834 »</TD></TR><TR><TD CLASS="quote">as ever one has said get a new MC about 98% sure its that</TD></TR></TABLE>
yeah.. just buy mine
