hatch/coupe 1/4 transferable?
Guest
Posts: n/a
I know that they arn't completely the same because I ended up getting a hatch 1/4 panel instead of a 2dr coupe panel and it's much shorter but does anyone know off the top of their head if the lines run the same and the 1/4 panel from the hatch coule be cut and used to repair the rear 1/4 on a coupe?
be professional
Re: hatch/coupe 1/4 transferable? (H.crx-si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.crx-si »</TD></TR><TR><TD CLASS="quote">I know that they arn't completely the same because I ended up getting a hatch 1/4 panel instead of a 2dr coupe panel and it's much shorter but does anyone know off the top of their head if the lines run the same and the 1/4 panel from the hatch coule be cut and used to repair the rear 1/4 on a coupe?</TD></TR></TABLE>
Not really, since the hatch and coupe had different wheelbases, rear windows, and rear ends. You may be able to use small sections of it but obviously not large sections.
b20vtech
01-08-2009 08:51 PM
gribbs
04-12-2003 10:40 PM
