after hydrid swap reverse lights didn't work
here is a brief history
i got a civic coupe 95ex (AUTOMATIC)
recently got a GSR-97 swapped in....with manual conversion...everything going right except when i reverse my car or back up ...my rear reversed lights didn't work....anyone know why ...soeone have done this before please help me out..
oh one more thing is that my headlights high bean are working but not normal headlight...so everytime i drive at night i have to turn on highbean for them to work...
thank guys
thank guys
Re: after hydrid swap reverse lights didn't work (yeegsr)
theres a sensor on the tranny, near the passenger side torque mount. left of the header. make sure its connected, or even wired up
Re: after hydrid swap reverse lights didn't work (Downey)
will you give me a visual picture out of it......or a more detail of it location...let say i stand at the front bumper
follow the wires to the bottom left. the switch (19mm) is on the bottom front side of the tranny
awsome i was suspicious of that wire on ur first reply...well thanx for the picture man...really do..
which fuse to replace...?
when you do an auto to manual conversion, you have to do some extra wiring to get the reverse lights to work. Most people never bother (like me), but there are write ups on it. Nothing out of the ordinary. I know it has something to do with sending the wires from the reverse switch back to the auto shifter plug....
You may need to fill up your headlight fluid. You're probably running low.
I've heard of this problem before. Try searching GOOGLE for it or call race shops and ask for their opinion. Good luck!
1 Post
Re: (TheIntegraGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheIntegraGuy »</TD></TR><TR><TD CLASS="quote">You may need to fill up your headlight fluid. You're probably running low.
I've heard of this problem before. Try searching GOOGLE for it or call race shops and ask for their opinion. Good luck!</TD></TR></TABLE>
probably talking about tranny fluid??
anyways you need to run 2 wires from sensor on tranny to main harness where the auto shifter used to be and tap it in the plug. i'll try to get pics
Re: (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">
anyways you need to run 2 wires from sensor on tranny to main harness where the auto shifter used to be and tap it in the plug. i'll try to get pics</TD></TR></TABLE>
cool please man...thanx guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">headlight fluid ....?huh what ?
Sarcasm..
Sarcasm..
Re: (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">probably talking about tranny fluid??
can you give me a little write up and some picture for the process
thanx man...
thanx man...
Hondas are like Drugs (addictive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downey »</TD></TR><TR><TD CLASS="quote">theres a sensor on the tranny, near the passenger side torque mount. left of the header. make sure its connected, or even wired up</TD></TR></TABLE>I had this same problem, and all it was ...was this sensor not being hooked up
