abs brakes
abs brakes
i'm just looking for info about abs...I have it on my 94 civic coupe, i'm swapping the motor and i was wondering if i had to keep the abs or if i would have to do anything to the brakes to make them function w/o abs?
your brake system is completely separate form your engine (except for the vaccum sorce for the power booster). so if you swap, ABS will stay. if you want to temporarily turn off the ABS (ie if you want to do threshold braking for auto-x or road racing), pull up the e-brake just high enough to turn on the BRAKE idot light, and drive about 1/2 a mile. your ABS light should come on, and your ABS will be deactivated. if you don't know how to threshold brake DO NOT turn it off. you will brake much worse w/ the ABS off.
1 Post
Re: abs brakes (TealGreen94)
Jared is swapping out the engine. And while it is out he was thinking of removing ABS. He is wondering what he needs to do to remove it and will the ECU and brake system still work. Or does he have to change some parts?
