building a head
building a head
I have a 96 civic DX and want to do a mini me conversion with a D16Y8 head. However I want to build the head before putting it on my block. I am planning on sending the head to the shop(multi angle vale job, wet-tank, shaved, and port & polished) to be built with the parts that I buy which are: Skunk2 valves, Skunk2 dual valve springs, Skunk2 titanium retainers, Ferrea locators, Ferrea seals, Manley locks, a Crower stage 1 street cam, and a Skunk2 cam gear. Is this a good way to increase horsepower and make a strong head if I were to turbocharge? Do you have any ideas on how to make it better?
Also, I will be upgrading the fuel system: I want to use 1 of the 2 intake manifolds, the D16Y8 manifold (I heard it was considered the D-series type R manifold, is that true?) or a Skunk2 manifold (Both will bo Ported and Polished), Venom hi flow fuel rail, Venom fuel pressure regulator, Venom T-body, Aerospeed hi pressure fuel filter, Walpro 255 lph fuel pump, Precision Turbo 310cc injectors, Full stainless steel braided hi pressure fuel lines from tank to engine compartment. If you have any suggestions please let me now.
Alaniz Competition Fully Built GSR Head +Skunk2 Pro1 cams/manifold/gears/fuel rail/type r valve cove
gezzuzz
11-08-2008 11:53 AM
urbansi
09-20-2006 05:37 AM
The G2 Racer
02-19-2004 01:43 PM
