Will raising my compression do anything for me right now?
I've got a B18C1 in my 93 Civic with intake, header, and exhaust and I have messed up rings so I just bought some JDM Integra Type-R Pistons and rings. Online I read it's going to raise my compression to 11:1. Will this yeild any gains right now? I'm going to be getting my valve train upgraded soon but just wondering.
Thanks
Thanks
Re: Will raising my compression do anything for me right now? (bboyoxygen)
It should raise HP a bit, as well as the possibility of detonation... at the least, which you probably already are, use premium gas.
Re: Will raising my compression do anything for me right now? (CaptivaBlue)
Thanks, yeah I use premium gas. In cali we only have 91. I'm going to go skunk2 stage 2 cams with upgraded valves, springs and retainers and run hondata so I can get it tuned pretty soon.
From what I hear, get the new springs/retainers but save your OEM valves as long as they are in good shape, unless you're gettin' oversized or something, but I think Skunk2 doesn't say to run oversized valves with their cams.
Don't judge or question
If your going to raise your compression I would go a little higher than 11.1:1. I would go to 12-12.5:1 if you have the money to have it tuned if not your could go as high as 11.5:1 untuned. I ran 11.5:1 untuned for over six months without any detonation.
my house has wheels on it
would like to know also my engine is in pieces right now waiting on same pistons to show up...........also i thought c/r went to 11.6:1 with jdm itr??
Re: (BrokeAssWhiteboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssWhiteboy »</TD></TR><TR><TD CLASS="quote">would like to know also my engine is in pieces right now waiting on same pistons to show up...........also i thought c/r went to 11.6:1 with jdm itr??</TD></TR></TABLE>
I believe its around 11.2.
It would be cheaper to go with pr3 or p30 pistons and they will yield a higher compression. P30 will give you 11.5 and pr3 around 11.3. If you want to go higher go with ctr(pct) pistons, they will give you around 12.5. Btw, here is a compression calculator. http://www.bojangs.com/calculator/
Re: (spids5)
yeah i would just throw in some b16 pistons to give you an 11.5:1 compression ratio. that ratio will be a little better to use with your skunk2 stage2 cams when you get them. they are also way cheaper then itr's.
definatly get a vafc so that you can manage the higher compression correctly without the possibility of detonation.
i wouldnt go any higher than 12:1 on pump gas...thats just asking for trouble unless its tuned perfectly.
98ITRWhite
07-02-2003 02:35 PM
