h22 in an ek
h22 in an ek
how well would a h22 motor fit in a ek coupe i herd they are a little bigger so i gotta loose the ac and what not... just getting it out now i dont know much of anything about h22 motors so be nice lol
well there are kits that make you keep a/c as well as p/s pros and cons, can't really help you there, but what are you looking to get out of the h22 if you swap it in?
Re: (JDMChrisEK)
I did an h22 into ek..Distributor had me confused for a sec..but there is write up everywhere for that. Its been done a million times..
Re: (JDMChrisEK)
HI in response to the H22 swap in the EK....
I am currently swaping an H22 into my HX ( it was also an auto to manual conversion ) this swap is definitely not cheap [....especially for this model civic ) the swap is still currently underway. There have been some complications with the engine mounts the passenger side sub-frame needed to be replaced w/ one from a 5 speed. The complications go one....but never deterred me to not go all the way.
Obviously, you won't be keeping your A/C or power steering ......it never bothered me.
IMO there are many positives in swaping the H into an EK car....it will be a great platform for many things...which way you go is your choice. I chose the swap because of the difficulty level and for what I wanted out of it in the end.
Just as a tip make sure you find someone truly capable of completing this swap-research there work and WIRING ( anyone can put a motor in your car---but not everyone can make it run RIGHT!!! ) if you do it your self I hope you have experience.....
HOPE THIS HELPS ALITTLE!!!
dont look at the h22a faw sticky in the hybrid forum or anything: https://honda-tech.com/zerothread?id=650329
