so... which is which?
i'm having a heck of a time trouble shooting. below is a picture of the vtec pressure switch... 2 pins are labeled also (#1 and #2) now, which pin is supposed to be connected to the GROUND?
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">im almost 100% positive that 1 is power and 2 is ground</TD></TR></TABLE>
I agree.
I agree.
hey ... didnt i already help you on aim?? and ithought u said it worked??? ok anyway.. you told me you had the clip for it.. there is 2 wires on that clip.. the black one is ground and the other goes to the ecu
here's something to think about.... it's a switch. it doesn't care which is which.
All it does is connect the two pins together when the oil pressure is high enough. Neither are directly connected to the case or you would only have one wire.
so to answer your question, it doesn't matter.
how is the car wired? like everyone said. 1-ECU, 2-ground.
Re: (Relic1)
i have wired #1 to the ground and #2 to the ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">here's something to think about.... it's a switch. it doesn't care which is which.
[\QUOTE]
i hope so...
[QUOTE=siregcivic]hey ... didnt i already help you on aim?? and ithought u said it worked??? ok anyway.. you told me you had the clip for it.. there is 2 wires on that clip.. the black one is ground and the other goes to the ecu</TD></TR></TABLE>
just double checking because somebody said i might have a short somewhere because i'm still gettting a weird noise.
[\QUOTE]
i hope so...
Re: (idriveadelsol7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 »</TD></TR><TR><TD CLASS="quote">just double checking because somebody said i might have a short somewhere because i'm still gettting a weird noise.</TD></TR></TABLE>
ok I'll ask... what weird noise???
what's it sound like? where is it comming from (aprox area)
1baddc5
19
02-12-2007 06:14 PM
iphatcrxi
03-07-2005 09:52 PM
