Turning over slowly = dead battery?
I tried to start my recently built motor this afternoon and finally got it to turn over, however it was very slow and wouldn't start. I have a mini battery in the car that was not used for a year, so I had it hooked up to the battery of a running car with jumper cables. Do I need to replace or recharge the battery?
GDD Member
Jump start the car, drive it around for a while to get the electrolyte in there moving around, go home park it, jump start it in the morning, do the same routine. It'll start holding a charge after about 4 jump starts, if not, then the battery is bad. OR you can just charge the battery for a full day, then throw it in and it should be fine.
Re: (slomofo)
batt is probably dead, don't even bother with it unless it was $$$$, otherwise cop a new one and foget the headache, then you can single that out as even being an issue
Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo »</TD></TR><TR><TD CLASS="quote">Jump start the car, drive it around for a while to get the electrolyte in there moving around, go home park it, jump start it in the morning, do the same routine.</TD></TR></TABLE>
Gatorade?
Gatorade?
vizsual00
08-11-2003 11:48 AM
