which ls ecu for 98 honda civic ex
i know i need a p75 odb II, but i've heard there's diff. kinds like an ao-5 or something. i've never ran a regular ecu on my current setup (hondata) and i'm converting it all back to stock.
its a 2000 LS motor in a 98 civic ex. didn't teg's come with immobilizers and should that affect the ecu i buy?
Re: which ls ecu for 98 honda civic ex (leadtrum)
what you want is to use a '96-98 spec p75 ECU ('99 is acceptable but not all will work), as the plugs will be compatible and you'll stay with OBDIIa system.
OBDIIb started in '99 uses different plug arrangement as well as immobilizer on some models. this will not plug into the your harness, without a harness converter.
PhatBoy5015
33
10-29-2017 11:42 AM
