compression numbers too low????
Old 08-31-2005, 06:16 AM
Hondizzle!'s Avatar
Default compression numbers too low????
I just got done building my b16a2, I used wiseco 9.1:1 compression pistons and a cometic hp gasket. It only has about 200 miles on it since the build and I decided to run a compression test on it to see how it was doing. I got 125 across the board, this seems low but they are all dead even, is there anything that i should be worried about ? The car runs great and seems very powerful although I have yet to run it hard, until its broken in of course.
Old 08-31-2005, 06:20 AM
Will you make something up for me please?
shamoo's Avatar
Default Re: compression numbers too low???? (Dx2dR95)
Are you doing the test while WOT? Numbers are drastically reduced if you don't. It IS a good thing that the numbers are the same across the board though.
Old 08-31-2005, 06:23 AM
Hondizzle!'s Avatar
Default Re: compression numbers too low???? (shamoo)
no the tests were not done at wot i was unaware that was necessary
Old 08-31-2005, 06:30 AM
99blusi's Avatar
Put the pedal to the floor and do the test again. 125 is definately low for 9.1:1
Old 08-31-2005, 06:40 AM
Hondizzle!'s Avatar
Default Re: compression numbers too low???? (99blusi)
alright will do thanks for the info
Old 08-31-2005, 07:22 AM
SoSlo's Avatar
a compression test should be done with the engine warm and with WOT
Old 08-31-2005, 12:59 PM
Hondizzle!'s Avatar
Default Re: compression numbers too low???? (SoSlo)
yeah it was warm but not at wot thanks for the input guys
Old 08-31-2005, 01:01 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dx2dR95 &raquo;</TD></TR><TR><TD CLASS="quote">yeah it was warm but not at wot thanks for the input guys </TD></TR></TABLE>
Based on your numbers, and that they weren't at WOT, it seems that your motor is in good shape. Most important is the variance between the numbers. You got 125 across the board, which is
Old 09-12-2005, 02:50 PM
Hondizzle!'s Avatar
well i had a chance to do the test again and the numbers are exactly the same, 125 across the board, i tested wot and closed throttle, the only difference was that it built the compression faster with the throttle open
Old 09-13-2005, 09:13 AM
Hondizzle!'s Avatar
any thoughts
76 camaro car
04-20-2017 04:47 AM
88 civic
04-05-2009 03:21 PM
crapanese
10-30-2006 10:25 AM
snowblind7x
04-13-2005 08:12 PM
thao4life
10-08-2002 03:46 PM
Quick Reply: compression numbers too low????
