hard to remove yellow connector in fuse box?
I'm trying to take the fuse box out, and for some reason I can't disconnect this yellow cable that's going into it. Has anyone else had trouble with it and/or know how to get it out? It seems that depressing the little button that's on it doesn't do much.
u push that little button in...lol its not that hard. if it comes down to it take a flat head screwdriver and push in the button while pulling gently on the wire.
Re: (JDMlyfestyle)
you will notice I didn't have trouble with any of the other connectors I've tried using pliers and a flat-head screwdriver already
Re: hard to remove yellow connector in fuse box? (Aphelion)
careful when dealing with airbag wiring and equipment. follow factory directions, lol just apply enough pressure on the clip, it should come right off.
there is a little piece that is right above your arrow on your pic that you have to flip up first before you can pinch and pull. its to insure that that it doesnt come out easily and disengage the airbag.good luck
EG MikE
42
01-10-2007 04:11 AM
