Compression readings good or bad. 95 Civic Dx 171k miles
my car is suffering from lack of power, i was thinking the compression was horrible, but doesn't look too bad to me.
1 - 150
2 - 145
3 - 145
4 - 135
I am going to change the plugs. distrib cap and rotor, to see what happenes. just to think this is the only car i haven't fucked with, and drove into the ground 171k miles. woot woot.
1 - 150
2 - 145
3 - 145
4 - 135
do it again... make shure the engine is at operating temperature.. pull the ecu fuse.. and unhook the power to the dizzy ... cuz i have heard of people frying coils...
pull all spark plugs...i cant remember how.. or 1 at a time and crank it over till the needle stops moving.. it should be like 5 rotations..
my friend has a 94 del sol with the dx motor in it and 160 thousand on the motor driven hard most of the time and he got 185 183 180 177
Re: Compression readings good or bad. 95 Civic Dx 171k miles (dem0nk1d)
the motor was tested at operating temp. i drove at least 12 miles on it, pulled the plus and tested. so i belive soon it will be time for a new motor.
i have the same problem, lack of power,
all i did was change the coil in the dizzy
and it running better.
Re: Compression readings good or bad. 95 Civic Dx 171k miles (93egsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsedan »</TD></TR><TR><TD CLASS="quote">4 seems a little too low, shouldnt all of em be within 5 of each other? </TD></TR></TABLE>
135 psi is the minimum serviceable compression. 180-185 psi is typical of a good engine. 28 psi is the maximum variation between cylinders. Do a leakdown test to determine if it is the piston rings or the valves that are causing the low compression.
scooby_dooby
11-21-2003 02:03 PM
