How can i run a automatic harness on a manual trans?
I have a 96 civic i am doin a b16 swap into and the person i am doin it for got me a 97 vtec harness but for an auto. How can i make this work? Also it came with a p30 jdm ecu what do i need to run that also?
Re: How can i run a automatic harness on a manual trans? (ITR.#1446)
Just use the harness and cut the extra auto plugs. Is the p30 OBD2? If not get a jumper harness.
Re: How can i run a automatic harness on a manual trans? (Luserkid)
why dont you use the origianal harness ???all you would have to do is add a wire for a knock sensor, oilpressure switch and vtec selonoid vs. cut the harness apart and repinn the distributor.
Re: How can i run a automatic harness on a manual trans? (rainforest)
the motor came from japan has right hand drive setup........and the car was just a shell so i dont have and the only thing the kid gave me to do his swap is an auto harness froma 97 civic ex. im tryin to find a harness but i cant find any in the classifieds
eebaker
11-19-2017 04:47 AM
1992 civic Jdm BOY
02-20-2007 07:27 PM
