Replacement Motor Mounts [polyurethane bushings]
I'm trying to find some replacement motor mount bushings for my '93 Civic Si (stock D16Z6). Atleast 2 of them are completely dry rotted and worn out (broken into 2 or more pieces). It looks like the energy suspension kit and the prothane kit are just pieces that go over the stock rubber and reinforce them. Are there any other kits out there other than the $400 HASport kit. I just need some polyuerethane bushings that fit in the stock mounts. Thanks for the help.
Sean
Sean
Re: Replacement Motor Mounts [polyurethane bushings] (SCCAsean)
What motor mounts are you guys using. Should I just get newer stock mounts and get the energy suspension support inserts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCCAsean »</TD></TR><TR><TD CLASS="quote">What motor mounts are you guys using. Should I just get newer stock mounts and get the energy suspension support inserts?</TD></TR></TABLE>
Sounds like the best solution to me.
stockcrix1616
07-23-2003 10:32 AM
