Y8 intake mani install questions with pic.
I am installing this mani on my my 97 w/ a y7. What all needs to happed here? JB weld? I will be reusing the y7 TB with the y8 rail, injectors, sensors, etc.
Modified by Wilky at 11:01 PM 8/31/2005
Re: Y8 intake mani install questions with pic. (Wilky)
Yes just JB weld those four holes. also when did this swap i used the ex injectors and was throwing a CEL for fuel system rich. Replace with my old dx injectors and no CEL. pm if you have any other questions. good luck
Re: Y8 intake mani install questions with pic. (GripStar)
yes only the 4 little hoes need to be jb welded, ignore the nipple in the middle, and I hope your car is automatic because thats an auto TB and mani I see there.
I just finished my y8 mani swap last weekend. JB weld will work, I also JB welded the holes for the ICAV in the back of the manifod (if you picked up the y8 manual mani)
From the pic, I don't see the throttle cable bracket. My y8 mani was missing that and it took two days for honda to get that part in, so if you don't have the cable bracket, I suggest you get it before you do the swap
NHB
04-03-2007 04:29 AM
lkailburn
75
05-09-2005 01:06 PM
CaptinMcnut
11-22-2004 09:08 AM
