Car Acting Up!!
Car Acting Up!!
Ok, so I swpped an LS motor with a '00 si tranny into by ek, its been about a month or so and the thing is staring to act up. I'll be just crusing and it seems like the clutch will "disengage" (like pushing in the clutch to change gears) and then it will "engage" again. Is that the clutch slippin? I have no problems gettin into gear, no grinding or anything.
Sorry for the not-so-good explaination.
Re: Car Acting Up!! (greyhatch90)
here is a slightly better explination:
I would be on the freeway cruising, next thing you know your car wasn't responding to the gas pedal and it feels like the car was rolling dead in neutral. This only lasted maybe 1-2 seconds. It has also happened from a dead stop where I would hit the gas pedal and it would do absolutely nothing. A second later the car would rev up because of me already having my foot on the pedal and would drive on normally.
Sounds like the same problem I have currently. Mine doesn't do it from a stop though. Only happens sometimes when cruising ...Check your timing. <FONT COLOR="red">TDC</FONT>(Top,Dead,Center) goodluck
