some ?'s about compression results..
visited the track last night and friends noticed some blue smoke from exhaust during burnout and through 1st/2nd gear. when i got home there was tons of smoke from the exhaust and also noticed a good amount of oil from the valve cover breather, then figured some rings were broken. did a comp. test today and here are the results...engine is a turbo d16y8 and it is tuned.
#4---210
#3---180
#2---180
#1---155
would these results still point to broken rings? also my new oil return had a very slight upward slope which may of caused the blue smoke but not the oil from the breather, thanks for any suggestions or comments..
#4---210
#3---180
#2---180
#1---155
Re: some ?'s about compression results.. (buddy4002)
I'd say your rings are gone on #1. Your car being on a upward slope wouldnt cause you blowing blue ( buring oil in chamber ). Nor would it cause that excessively low test between #'s 4 and 1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buddy4002 »</TD></TR><TR><TD CLASS="quote">thanks for the input.. the upward slope i mentioned was the turbo oil return line though</TD></TR></TABLE>
Wouldn't matter too much; there's definitely something wrong with the #1 cyl.
did you do a wet compression test? it would help in confirming if the rings are bad or not. but from the look of it, #1 is pretty much toast. way too much of a difference between 1 and 4.
Re: (buddy4002)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buddy4002 »</TD></TR><TR><TD CLASS="quote">it was a dry test, also the engine was cold</TD></TR></TABLE>
You should re-test when warm. If you still get low in #1, put some oil in there. If the numbers go up, it's most likely your rings.
if it were mine i would want to see those 180s above 200 on a turbo car. if you havn't done it already adjust the valves dead-on with spec. even if you don't think it's leaking there it's still a good idea.
model x
05-06-2006 12:03 PM
tianporn
10
07-20-2004 11:24 AM
