Fog Light installation help!!! for EG......!!!!!!!!!!!!!!!!!!!!!!!!!!
I n eed quick help
i connected the harness
2 to the fuse box ( light switch lights up )
the ground
relay and fuse are with the harness
harness on engine bay has ground
everything connected but fogs dont turn on!
FOG LIGHTS DO NOT TURN ON!!!!
any help please!!!!
the ground
any help please!!!!
Re: Fog Light installation help!!! for EG......!!!!!!!!!!!!!!!!!!!!!!!!!! (Black Cloud EG)
well you check to see if theres power getting to the bulb part ? sometimes also that connector gets loose for the bulb part also.
Re: Fog Light installation help!!! for EG......!!!!!!!!!!!!!!!!!!!!!!!!!! (BlueIntegraBoy)
did u check the fuse for that spot where u plugged it into the fuse box?
get a volt tester and test to see if u get power to the red wire that goes thru ur firewall
Re: Fog Light installation help!!! for EG......!!!!!!!!!!!!!!!!!!!!!!!!!! (Znypar)
i will do all of them!
engine bay harness and cabin harness is connected
the harness already comes with a fuse
the relay's ground is good
ill check them on wednesday in auto tech class
you didnt say anything about the power wire from the engine harness part to the battery= no fogs
Re: Fog Light installation help!!! for EG......!!!!!!!!!!!!!!!!!!!!!!!!!! (zacatkings)
yes theres a fuse in the harness, but did u check the fog light fuse thats in the fuse box where u plugged ur switch power wire into...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zacatkings »</TD></TR><TR><TD CLASS="quote">you didnt say anything about the power wire from the engine harness part to the battery= no fogs </TD></TR></TABLE>
BINGO!!!
The depo kit for the 92-95 models says absolutely nothing about going to the battery. Took me a few minutes to figure out why everything but my fogs didnt work. THen i re-wired them to the lowbeam switch to stay legal.
BINGO!!!
Re: Fog Light installation help!!! for EG......!!!!!!!!!!!!!!!!!!!!!!!!!! (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">
BINGO!!!
The depo kit for the 92-95 models says absolutely nothing about going to the battery. Took me a few minutes to figure out why everything but my fogs didnt work. THen i re-wired them to the lowbeam switch to stay legal.</TD></TR></TABLE>
how do you do that lowbeam thing?
BINGO!!!
Ghetto Civic HX
11-14-2007 07:53 AM
