b18c gsr swap into delsol 96 si
b18c gsr swap into delsol 96 si. is this a straight swap or what?? can I use the current mounts for my d16y8 engine? sorry if this is a stupid question.
thanks for your help in advance.
Re: b18c gsr swap into delsol 96 si (delsolio1996)
Everything is pretty much a straight swap.
The only things in particular that you need is a shift linkage from a 94-97 Del Sol VTEC model (as this was the only del sol with a b-series engine), no other model will work, only the VTEC model for a Del Sol.
You'll also need any b-series axles if you don't already have them.
You'll also have to get mounts for either a 99-00 civic si, or a 94-97 Del Sol VTEC model. I know you can mix and match the mounts from both civics and integras, I just can't remember which at the moment. I am sure someone can help me out on this.
If you decide to keep a/c and p/s, again, you can ONLY use the brackets from a 94-97 Del Sol VTEC model.
James
James
TunesEK
19
04-15-2009 08:47 PM
shiftgear8000
04-08-2005 08:10 PM
90civichb
06-05-2004 04:13 AM
