please help, no driving till fixed, removal of axle from half-shaft
ok, im trying to get the axle out of the half-shaft on the driver side of my 93 si with a jdmb16 w/hydro lsd b16 tranny, i cant get it out and i have tried everything i can think of, i can find a good place to pry it out either, where does it seperate and where should i pry?, i pulled really hard on the axle in frustration and im pretty sure i seperated something since the boot just sides around on the cup when i turn the other side, help help help please
and this is what its going to look like till i get it fixed
Re: please help, no driving till fixed, removal of axle from half-shaft (EG93si)
Get a crowbar and pry that bitch off, lift up your skirt and get 'er done.
you need to remove the 3 bolts that hold on the half shaft and give it a good yank....it will come off then seperate the two bolt the half shaft in first then the axle ....not that hard really just time consuming.
Re: please help, no driving till fixed, removal of axle from half-shaft (stoopid monkey)
bfh prevailed again, thanks guys, and yes i did lift up my skirt and beat that thing like she didn't make me dinner.
also, i was suprised that the inner side is female, is that right, i thought it was male, but the half shaft had the splined piece that stuck out, is the 94 gsr wo/abs still going to fit fine?
Re: (jerm001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerm001 »</TD></TR><TR><TD CLASS="quote">just out of curiousity, whats that round thing between the two cv joint?</TD></TR></TABLE>
a vibration damper
a vibration damper
Re: (EG93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG93si »</TD></TR><TR><TD CLASS="quote">again, is the inner cv joint side suposed to be female on a b16 tranny? is a 94 gsr still going to be the right axle?</TD></TR></TABLE>
pass side is male
drivers side is female because it attaches to the intermediate shaft.
pass side is male
i have a zc motor with zc hydro tranny in my car.. the way i get the halfshaft off is get a big pipe wrench.. open it up. and put the teeth between the axle and halfshaft and hit it with a mini sledge.. as soon as the axle moves.. move the pipe wrench and hit it out with the sledge.. works everytime
SoOHiGH
18
07-06-2005 07:48 PM
HGZ
03-08-2005 01:12 AM
