swapping out the powersteering rack for a manual rack
should be pretty simple, has anyone else done it or ran into any problems? i would like manual steering, but would it just be easier to loop my ps lines together and loose everything involved with ps (pump, belt, hoses, resivor) and just T the lines together? than to actually swap in a manual rack> lemme know
Re: swapping out the powersteering rack for a manual rack (louie3252)
if you will not have a PS pump on there then you HAVE to put a Manual rack on. The PS pump will be harder to steer with than the manual rack. I just swapped mine out, and the only problem I ran into was that the bracket that holds the manual rack on the passenger side had the bolt holds in a slightly different position, so a little modification to the bracket fixed it. The car felt MUCH MUCH better with the manual rack on. Plus I got rid off all the PS lines, resorvoir and cooler making the engine bay look more clean and less cluttered.
Be sure to do an alignment after swapping the racks.
vtec4lyfe
01-08-2007 07:46 PM
