CTR axle mm question
94 civic cx hatch running jdm d16a.
i'm planning on getting CTR conversion and they said it uses 32mm axles. but i'm also thinking of swapping a jdm b18c into it. question is, what axle do i have to use to fit the CTR conversion and is that axle hard to find? i know the ITR is a bit hard to find but i herd the CTR is easier.
The CTR axle is a 36mm that goes into the hub where the wheel bolts up to.
These are a bit harder to find being that you cannot just go to any auto parts store and buy them.
Re: CTR axle mm question (lv6l)
You can use the CTR axle they will bolt right up to your application...they are 36mm...you should have no problem...they are hard to find your best bet is to go to driveshaftshop.com and they have different applications (ie stage 1,2,3) for your car...they are pretty cheap to.....good luck
Re: (orientalgunz_00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orientalgunz_00 »</TD></TR><TR><TD CLASS="quote">the ctr is not 36 mm...it is 32 mm...the usdm itr is also 32mm...the only one i know of that is 36mm is the JDM itr...</TD></TR></TABLE>
thats what i herd, but i wasn't sure.
This is correct
This is correct
correct indeed!
correct indeed!
so to answer my first question, if i do a CTR 5 lug conversion i can use my stock 32mm axles? and when i swap a b18c into it i can also use a 32mm axle? does any of the splines not match up to the CTR hub?
Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l »</TD></TR><TR><TD CLASS="quote">so to answer my first question, if i do a CTR 5 lug conversion i can use my stock 32mm axles? and when i swap a b18c into it i can also use a 32mm axle? does any of the splines not match up to the CTR hub?</TD></TR></TABLE>
Yes if you do the CTR 5-Lug conversion .....you can use ur stock 32mm axles....you can also use the 32mm axles when you swapp in the B18c, the only time you will have to worry about axle size is when you use JDM ITR axles (36mm) they WILL NOT<U></U> bolt up to the B18c...you will have to enlarge the splines on the B18c....
mrlegoman
12-22-2005 01:30 PM
