CEL 22 - VTEC pressure valve? need help!
FIXED PROBLEM
I got this CEL and dont know what it means. Ive been told it means low oil or bad vtec solenoid.. can somebody help me out?? I just barely swapped this motor in, bought it from PASSWORDJDM so I'm hoping its not a bad vtec solenoid.
specs:
99 EK
95 JDM GSR swap*stock
P30 ecu*I know I need a p72 but this is all i got for now
OBD2B to OBD1 conversion harness
Modified by 0LlY at 1:32 PM 3/27/2006
specs:
99 EK
Re: (aZnjCC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aZnjCC »</TD></TR><TR><TD CLASS="quote">dude....jdm motors don't have vtec pressure switches haha.
You'll need to ground the vtec pressure switch wire, or just connect it to the vtec solenoid pin out
ohh thought they did? well im going to splice the vtec pressure switch into the solenoid wire tomorrow
Re: (0LlY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0LlY »</TD></TR><TR><TD CLASS="quote">
ohh thought they did? well im going to splice the vtec pressure switch into the solenoid wire tomorrow </TD></TR></TABLE>
werd, that's what I did with mine...works like a charm
wiring to the vtec cylinoid or possibly to the ecu as well or bad cylinoid low oil also had the same problem and it was my wiring harness from the ecu and the wiring to the cylinoid
Re: (ondahush)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ondahush »</TD></TR><TR><TD CLASS="quote">wiring to the vtec cylinoid or possibly to the ecu as well or bad cylinoid low oil also had the same problem and it was my wiring harness from the ecu and the wiring to the cylinoid </TD></TR></TABLE>
huh? haha i kinda get what you said but again i didnt
95fourdoor
08-29-2012 01:01 PM
