How to change tranny fluid?
I bought some syncromesh tranny fluid that i wana put in my b16 tranny. Is there a write up how to flush your old fluid and put in some new stuff? Is it difficult? Any help would be appreciated. Thanks.
Mike
Mike
Re: How to change tranny fluid? (mikeunreal2)
https://honda-tech.com/zerothread?id=642479
You'll find a lot of other useful stuff in there and searching will help even greater.
i tried filling through that "vss hole" , and it didnt work to good.
i just created a funnel with a hose attached at the end of it and filled through the correct filling hole. that vss hole was just too small on my ej1.
Re: (graveltravel2)
thanks for attempting to be a jackass and tell me to search. i already searched and there is no diy or write up, so screw you *******.
searching can be a pain to certain people, but if you did search, you would've found this:
https://honda-tech.com/zerothread?id=382416
next time, don't post until you've checked all related threads.
Archived content search "tranny fluid".. hey what do you know, thread found...
Re: How to change tranny fluid? (skip.two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skip.two »</TD></TR><TR><TD CLASS="quote">searching can be a pain to certain people, but if you did search, you would've found this:
Archived content search "tranny fluid".. hey what do you know, thread found...</TD></TR></TABLE>
mikeunreal2 just got 0|/\|n3|)!!!!!!
Risky Business
Re: (mikeunreal2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal2 »</TD></TR><TR><TD CLASS="quote">thanks for attempting to be a jackass and tell me to search. i already searched and there is no diy or write up, so screw you *******.</TD></TR></TABLE>
-2%. Wanna go for more?
Re: (fmrprojects)
I just did my passengerside axle this past Sunday. I went to fill it through the VSS, but I couldn't get the fluid to go in.
I pulled the vss and the little rod that goes into it, but there were two thin metal things still in there, which I assume were part of the VSS. My speedo seldom works, so I figured that was part of the problem.
Anyway, I tried to fill it through there anyway, but no dice.
Instead I took the cover off of the vent on the front of it (it's clear as day in that axle replacement therad) and filled it through there.
mikeunreal2
10-14-2006 02:32 PM
