rim size
rim size
i was wondering if 17" rims will fit on my 94 civic with out changing any of my suspension will they rub or should i be good has anyone had 17s on their honda that could tell me
Re: (bsixteen)
They'll fit. I was running 18"x7-7.5" rims w/ low profile tires. Stock suspension they didn't rub at all, but the car looked like a 4x4.
I have the car lowered on Tein S-Techs and I would get occasional rubbing, but nothing major.
They'll fit, but you'll have to go with a low-profile tire and if you don't lower it the car will sit like a 4x4.
Re: (specscow)
If you're going to get a nice wheel I'd say 17 is fine, but make sure you lower it at least a little bit, as well as get a camber kit.
17"-18" tires can be expensive (I think Kumhos for my 18"s are around $100/piece).
It's really personal taste. If you like the 17s then get them. I no longer like my 18s simply because of the extra weight (cheap motegi's I got from a friend, very heavy), instead I run my steelies. I might get a set of the hubcap spinners just for ***** and giggles.
I've heard that 16" tires can be a pita to find. Personally I'd go with a 17" wheel just because I like the look of the bigger rim with less rubber.
Re: (Everyones Hero)
the only reason im going so big with the 17" rim is because i have a set of low pro yokohamo tires for 17"rims already yokohomo does any one have any pics of their car with 17s on their car before they lowered it
Re: (specscow)
to some eyes 17s look better than a smaller rim, but any performance benefit is unfounded. typically a larger rim like that will add weight, and detract from the ride quality and braking ability. by the way-what's the sidewall height on those tires you have? ex:205 R17__?
