whats the ECU i need for a H22A?
i have a complete H22A with no ECU, its a 2nd generation (i think, its a 92 95) but i have no idea witch i need.......... suggestions?
wow you guys need to search, but to edify:
you can use the p13 ecu, but make sure it's american, cause i've only seen crappy jdm ones(w/ the 4ws that is...makes em not run right imo)...you can get a p28 chipped or a p72 chipped as well i believe...
Re: (tehpr3chr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tehpr3chr »</TD></TR><TR><TD CLASS="quote">wow you guys need to search, but to edify:
you can use the p13 ecu, but make sure it's american, cause i've only seen crappy jdm ones(w/ the 4ws that is...makes em not run right imo)...you can get a p28 chipped or a p72 chipped as well i believe...</TD></TR></TABLE>
yep, p13 is stock, and p28 or p72 are the best if you are going to chip them. Make sure it is obd1 though, regardless of which you use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICE_CR »</TD></TR><TR><TD CLASS="quote">have no idea, i have it right now with a b16z6 ECU but i need / whant the original
if you mean d16z6, then you already have a p28, get it chipped, and use H22 maps only, don't run it on B series maps.
Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">
if you mean d16z6, then you already have a p28, get it chipped, and use H22 maps only, don't run it on B series maps.</TD></TR></TABLE>
whats the advantage of running a p28 as opposed to the stock p13?
Re: (hondasport2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondasport2000 »</TD></TR><TR><TD CLASS="quote">
whats the advantage of running a p28 as opposed to the stock p13?</TD></TR></TABLE>
tuning, only important if you plan to mod the engine beyond the basic bolt-ons.
so if i get it chiped it will work like a h22 ecu?
Re: (RICE_CR)
so if i get it chiped it will work like a h22 ecu?</TD></TR></TABLE>
if you get it chipped the ecu will run like whatever chip is in it. the chip reprograms the ecu's fuel and ignition maps. I'm using a chipped p28 for my H22.
Re: (IHateJDM)
al right thats what i need to know... thanks....
the thing is that i have the engine in a 93 del sol but it didnt had the ecu it came with the p28... but if chiped will work well so ill get it chiped right away!!!
Re: (RICE_CR)
the is that i have the engine in a 93 del sol but it didnt had the ecu it came with the p28... but if chiped will work well so ill get it chiped right away!!!</TD></TR></TABLE>
make sure its a vtec ecu though. vtec is built into the board, not the chip. that's why p28's (sohc vtec) and p72's (GSR) are so popular. If you chip a non-vtec ecu, the fuel and ignition maps will be right, but vtec will not engage.
